Posts: 338 |
is the back spacing the same for the front and back?? I have 275 60 15 on the back and 215 70 15 on the front and they still rub when I turn left... ??? all four rims are the same
1967 firebird
Posts: 7,495 Likes: 1
Posts: 7,495 Likes: 1 |
Same BS front and back. Could be many reasons but mostly the car was never designed to run tires that wide in the first place. On top of that they never came with 15" wheels either. They rub because the wheels and tires aren't made to fit on your car.
Posts: 10,337 Likes: 3
Posts: 10,337 Likes: 3 |
Same BS front and back. Could be many reasons but mostly the car was never designed to run tires that wide in the first place. On top of that they never came with 15" wheels either. They rub because the wheels and tires aren't made to fit on your car. x2
Posts: 4,248 Likes: 14
Posts: 4,248 Likes: 14 |
I just put 215-70-14 tires on stock R2's with no rubbing. That may be the biggest tires that will fit with no mods. I had 215-65-15's on repop R2's which looked great but rubbed when I had a passenger and hit a speed bump.
Posts: 173 |
What wheels do you have installed? The 215 70 15 is almost 27" in diameter
I have 15x8 Rally II's [all around] with 4.5" BS. The tires are 235 60R15's [26" dia] and they don't rub.
PeteJD [69 400/400]
Posts: 1,170 Likes: 1
Posts: 1,170 Likes: 1 |
I'm gonna sound real ignorant, but WTH is back spacing? You talking wheel spacer?
Don't know till you know...it's the depth measurement from the bolt mounting surface to the tire bead lip on the back side of a rim.
Posts: 338 |
I have 15x8 Rally II's [all around] with 4.5" BS. The tires are 235 60R15's [26" dia] and they don't rub. keystone klassics.....15x8... 4.5 backspace.... I'm sure the QA1 control arms is the issue in some way.. I'm gonna go down one more tire size..
1967 firebird
2,192
74
