I
I Offline
whats the best covers for the deluxe interior in black,,, legendary or pui not sure if there are others . I have the comfort weave style just wondering what you guys had the best luck with?
D Online: Content
I can't speak for deluxe covers but the standard covers by Legendary are very nice.
Thanks,
Dennis
Note that, unless the repro manufacturers have changed the material they use, true breathable Comfortweave is not used. In the past, each had been using a stamped solid material that has a Comfortweave-like appearance.
Here are three samples (front and back) I collected eleven years ago when I did mine. Real Comfortweave on the left and two versions of the material they were using for the repro covers center and right. You may want to get manufacturer/vendor samples today to help you decide which you like best.
Back then, some real Comfortweave and matching Madrid vinyl was still available at SMS Fabrics, so I had mine made using that.
'68 400HO Conv.
You can get the correct comfort weave material from SMS (https://www.smsautofabrics.com/) and send it to Legendary to make the seat covers with from what I hear. May be a good option. The true comfort weave is worth the extra cost.
