New Member
New Member
Posts: 3 |
Hi everyone, I finally found a good car. 68 with 400 and th400
She is all original, ps,pb, ac
It has an open Carrier with 2.56, 😁
I would like some recommendations on which gear company I should go with, auburn eaton etc.
I'm thinking 3.36 for the auto.
Plans are to keep car all original but update the brakes, suspension and create a solid handling braking car I can drive whenever. Only has 68k original miles.
I really appreciate you're input
1968 Pontiac Firebird 400 Verdero Green on blk interior Custom 4 link / Coilovers / Mini Tub Baer 6 piston front/rear
Posts: 1,529 Likes: 41
Posts: 1,529 Likes: 41 |
Auburn is fine for what you want. Hope you have someone local that knows how to set up a rear.
Posts: 1,459 |
The Eaton posi has advantage of being rebuilt easily. The 8.2 is stronger than people claim, can handle 450hp without breaking, would put stronger axles in IMHO.
Posts: 7,719 |
The Eaton posi has advantage of being rebuilt easily. The 8.2 is stronger than people claim, can handle 450hp without breaking, would put stronger axles in IMHO. Or magically get your hands on a 8.2 HD 4-pinion nodular rear.
Posts: 3,615 |
I have an Auburn. All good.
Didn't know 3.36 was an option in the 8.2....? Thought it went from 3.28 to 3.55...
"The Eaton posi has advantage of being rebuilt easily. The 8.2 is stronger than people claim, can handle 450hp without breaking, would put stronger axles in IMHO." ... don't put sticky slicks on it and it can handle anything!
Posts: 7,719 |
New Member
New Member
Posts: 3 |
So I ended up doing the Auburn with Currie Axles. Butler 505 going in car soon, will see how long it lasts.....
Posts: 173 |
With that much power it'll be interesting to see how long that 8.2 will last, good luck.
I have a Lok-rite LSD and it's a little noisy, but it works well and doesn't have any friction discs. Best of all you don't have to remove the carrier to install it. I also wanted to stay with a BOP diff and the Lok-rite fits the small carrier used with the 3.23 gear.
PeteJD [69 400/400]
410
58
