#318216 07/24/18 12:31 PM
M Offline
So I have a sunoco near that has turbo blue 110 octane.
I have a wz 400 with 62 heads ( might be 10:1 )
Is this recommended ? it is expensive but is it kinda better ?
MT69-400 #318227 07/24/18 03:02 PM
Try it. You'll like it!...your stock 400 with 62 heads will light up like a Christmas tree!!!
Put 5 gallons of it in every tank full.
Lather. Rinse. Repeat...LOL
MT69-400 #318229 07/24/18 03:05 PM
Sure which I had easy access to that stuff.
1980 Turbo Trans Am
1988 Mustang GT, 5 speed
1983 F-150 4x4, built 302
MT69-400 #318231 07/24/18 03:10 PM
M Offline
So at 8 dollars a gallon I can run 5 gal of this and the rest 93 and be good and happy ?
Begs the question much different if I run it straight at least to try it out smile its [censored] expensive
MT69-400 #318236 07/24/18 05:21 PM
FWIW.
Have a 461 with about 10.2cr/234/244 - 110lsa mft cam.
Before starting complete body work years back(another story...) I mixed 50/50 87 octane(w/10% ethanol) with 93 octane.
After over 500 hard street driving and at least 100 1/4 mile strip runs at 114 mgh, while engine was out inspection on bearings and heads checked perfect.
My car hates me...
MT69-400 #318243 07/24/18 10:02 PM
Ya never know 'til ya try.
Are you having detonation problems?
MT69-400 #318249 07/25/18 07:45 AM
W Offline
Higher octane by itself doesn't help you unless you have a detonation problem. Other parts of the gas might have minor benefit but unless you are pushing the limits of your engine, you won't see anythjng but a drain on your wallet.
http://www.superchevy.com/how-to/car-care/1509-everything-you-need-to-know-about-octane/
MT69-400 #318250 07/25/18 09:40 AM
High octane doesn’t contain more energy than low octane. The benefit is the ability to use higher compression and more timing advance to produce more power. Depending on your motor setup, there may be no benefit
MT69-400 #318257 07/25/18 12:52 PM
When my 400 was pretty much stock, 16 heads, using the higher octane fuels made a noticeable difference. I mostly used the Low Lead 100 I could get at a small local airport. My engine responded well to this fuel. ... And the exhaust smelled better. That fuel was only $1 more, or so, than premium pump gas. ... And I might drive 1,000 miles per year, so...
Was it necessary. No. Did I like it? Yes
Try it for yourself and see if there is any noticeable difference. I look forward to your comments.
MT69-400 #318259 07/25/18 01:21 PM
M Offline
not much diff
I never had a detonation issue, I think ill save the money.
I believe its a stock cam
I should check the actual compression since they are 62 heads
W Offline
This...if it were no difference in price better smelling gas would likely convince people we are doing good things for the environment burning hydrocarbons.
MT69-400 #318274 07/26/18 09:14 AM
There is no "better gas" anywhere in the counties surrounding Chicago so I have to use additives with fill-ups of 93-94 octane corn squeezins. If I didn't the marbles rolling around in my engine on acceleration and the lack of valve seat protection would do damage.
'68 400HO Conv.
MT69-400 #318275 07/26/18 10:23 AM
I usually run my 389 bird on 93 octane. It knocks and pings at WOT but runs ok otherwise. I needed gas the other day and there was only 91 octane ethanol free available. The increase in pinging was noticeable just from 2 less octane. I wish they’d sell 95 octane
