Does anyone know if a 68 and 69 console “T†shifter are basically interchangeable for a powergide? I’m restoring a 69, and have found a 68 shifter only. Thanks, JD
Powerglide (super turbine) and th400 shifters are different if that is your question. Both come with t shifters.
The difference between Powerglide and the TH400 are the detents. The same shifter will work, but you may not be able to shift through all the gears yourself (put in 1st and go up). Mine works fine but I do believe it has the detents for a Powerglide. https://shiftworks.com/collections/...-firebird-factory-shifter-conversion-kit
There may also be handle differences.
