4 Offline
Hi,
Has anyone replaced the firewall pad with either the flat or molded versions? The molded ones run about $180.00 vs. the flat ones around $40.00. It is worth the extra money for the molded one, or are the flat ones good enough? There is a huge price difference.
Thanks
We are talking about the jute backed rubber insulation on the interior side of the firewall, correct?
Through the magic of 3M spray adhesive, the flat one will fit OK. Mine had to be stretched a bit to get all the pre-cut holes to actually line up. It could have been better.
1980 Turbo Trans Am
1988 Mustang GT, 5 speed
1983 F-150 4x4, built 302
4 Offline
Thanks, yea the jute pad. Thanks for the reply. I’m thinking the same and going with the flat one. 3m spray adhesive also, thanks I hadn’t thought about that yet.
IMO put down some dynomat stuff down first before the firewall pad.
4 Offline
Yeah probably will use some heat barrier like dynomat. Thanks.
