New Member
New Member
Posts: 3 |
I have just put my plastic dash bezel housing back in my 1969 Firebird with new gauges and A/C etc, but it appears I am missing some sort of bracket that is to the lower right side of the steering column to allow the lower dash bezel to screw into and mount in the area between the steering column and radio.
I have that left side filler bracket that also houses the flasher for the bezel to mount to, but I don't know what it is that is missing on the right side.
Anyone able to check their car and let me know what the dash bezel mounts to on the lower right side of the steering column?
Thanks!
Posts: 203 |
Hi Madgoat. I checked my bezel and the steering column collar. I too put in a new bezel. I just looked at my dash. My steering column collar just screws to the dash bezel on the right side. I don't remember any brackets between the steering column and the radio. If this doesn't answer your question please let me know and I will look again. Doug
Posts: 853 Likes: 3
Posts: 853 Likes: 3 |
there is a braket that goes there, it also has the plastic insert for the screw to screw into. where in Ca. are you?
Wade
Posts: 1,202 Likes: 1
Posts: 1,202 Likes: 1 |
Do you happen to have a pic you can post?
Posts: 853 Likes: 3
This is not my pic, this is from madgoat's post on the PY Forums. The pic is from nashcar on the PY Forums
Wade
2 members (Geoff, Jimc2002),
469
119
