Has anybody cut closed scoops to make open scoops? Is there a reason I can’t do that and need to buy open scoops?
Back in the day I cut a pair. If you can buy open ones for a reasonable price I'd go that route. In the end you have 2 good OEM parts whereas you cut, then you have one buggered pair.
The ones I cut were repops because my OEM ones had a stud broken off. But that was before you could purchase open repops. So yes, that is probably the way to go these days.
Keep in mind that repop hood scoops do not fit original hoods, and vice versa. So don't buy and cut just to find that out later.
The repop once I bought are not plastic, but like 68 said better check them if you go that route. Better to test fit them first and see if they fit correctly and return them if they don't..
I think I may have one original left if anyone needs one. Don't remember which side though.
What are the advantages in opening them up, I presume it is to get more air in the engine but will it not let to much in at high speed not to mention the bugs and if it is raining ?
I am planning to go with the ram air setup. Mostly for coolness factor. Bringing in cool air is also somewhat beneficial.
Heh Bob, If your opening them up for the RAM air setup then IMO blow holes in those puppies and let the air in! RAM Air setup is very cool and it does add value to your car. They found the location of the scope are wrong in that at higher speeds it tends to draw air out as opposed to in. That's why you see the formula hood on the 69 TA hood with the scoops at the very front. Real facing shakers eventually become the norm.
I spent the wad on my 389 TriPower engine (for my 65 Pontiac) just because of the triple 2 bbr battleship. Nothing else like it.
IMO, if you keep the car stock bu you want more accessories etc. just find other stock components to add to your car without it requiring irreversible changes.
I am going to add the following additional STOCK options: - tilt steering - console clock - cruise control - power brakes - 67 Tall type Hood tach - fold down rear seat - seat extenders (from Bill Edmunds) - '72 Pontiac overflow tank - NOS late 1970's red line bias ply tires (show only) - custom interior seats (I have both std and custom seats) - Remote mirror - RH mirror
Without the RAM air setup your going to bring in a lot or rain. If you take your scope off, have a peak at your distributor. It's going to get pretty wet!
