They can, but you would need a collar for the pinion shaft. You can contact a company like Randy's Ring and Pinion and they would be able to get you the right stuff.
That was Quick!!! Thank you!!! I see one on E bay really cheap right now and want to change the one I have. That's the only Flaw I have with the Firebird. 3.36 on a 400 car is a joke IMO Do you think its a good Idea or would you go with something different?
1969 GTO Convertible 1969 Firebird 400 1979 Trans Am 1995 Trans Am Convertible
That does not sound right, unless you are talking about the installation kit and a posi unit, plus the part I was thinking of which makes up the difference in the pinion shaft diameter between the chevy and he BOP pinion bearings.
As far as I know, it's not that big a deal.
What were they trying to sell you for that kind of money?
Also, since you're already in series 3 gears, I would expect you only need Richmond gears in the low 4's and an installation kit. the whole thing should cost you less than $400. (Or so I would think.)
I would shop around a bit more, I know 8.2's are very expensive to rebuild, I just wanted to replace my 3.08's in my 66 Lemans with a posi carrier(that I had already) and a set of 3.90's. Bottom line the ring and pinion were $275 the installation kit $118.00 some new bearings $70.00 and other miss. pieces and I had over $600.00 into my 8.2.
