I have a motor at the builder that is ready for the dyno. Any tips to try while on the dyno? Things like carb spacer and adjustments, different plug range, MSD dist could be dialed in. Should of would of could of?
You covered most of them. For me it was essential for proper carb adjustments and total timing.
My engine builder already knew exactly what spark plug to use based on aluminum (vs cast iron) heads and compression ratio.
