Hello, Can anyone tell me or have pictures that can show how the center console wire harness is secured? I also need to know how the dash harness is correctly routed behind the drivers side? Does it go in front or behind the 2 steering column support bars or behind the first and in front of the second support bar. Ty Norm
What year? my 69 Console only has the wire for the shift indicator light, that wire is ran under the carpet. Not sure what wires your taking about for the dash harness, my harness runs along the back side of the insterment cluster
The console wiring harness hangs from the underside of the console on 1 or 2 little hooks that the factory provided. That's all I remember.
Hello, Sorry i forgot the details, It's a 68 automatic and the wiring is the shift light, neutral safety switch and reverse light. I did run the wire down along the left side of the heater box and under the carpet to the center console however there is so much wire including the plug that I don't know where the wiring or plug gets secured to
From what I recall, the wiring ran under the carpet, popped up through a hole under the shifter area, and then plugged in to the underside of the housing. I do not think there were any clips or guides holding any of that in place.
