Dose anyone have a wiring diagrams for blower motor and Resistor and master relay The wire colors coming out of the fire wall don’t match any of my wiring diagrams I have Tan or grey Blue/white stripe Light green Black/white stripe Black/red stripe or orange stripe 69 with ac
I found discrepancies in wire colors between the '68 AC wiring diagram and the schematic on the '68 Diagnosis Manual too. For example, the wiring diagram shows a black-orange stripe to the blower motor yet my '68's wiring agrees with the Diagnosis schematic purple wire to the motor. I can post a '68 schematic but I have no idea how applicable that would be to the '69s.
I have the 69 diagram but it’s for a non ac car you have to go to the ac section and theirs another wiring diagram but the colors are different and doesn’t combine the blower motor wiring with the ac system So if anyone has a complete diagram please send it
Thanks Mickey I down loaded that one because when i rewired mine I didn't have that drawing and after I got it all done the high speed on the fan didn't run it turned out to be the master relay was bad . That relay is hard to find but if any one needs one I found it on amazon . https://www.amazon.com/Standard-Motor-Products-RY5-Relay/dp/B000C7ZTH0
