What does everyone recommend for transmission fluid on a 67 with ST300?
This will do the trick... NAPA Premium Dexron III / Mercon Automatic Transmission Fluid - 1 qt Desc: Features & Benefits
NAPA Dexron III/Mercon ATF Is Formulated w/ Advanced Additive Technology & Premium Quality Basestocks To Protect Automatic Transmissions Against Undersirable Deposits, Oxidation & Viscosity & Thermal Breakdown Under Severe Service Conditions.
Enhanced Anti-Shudder Protection For Smooth Shifting Performance & Protecting Against Slippage Superior Resistance To Viscosity Breakdown For Better Wear Protection Against High & Low Temperature Ranges Minimizes Sludge & Varnish Deposits, While Protecting Transmission Seal Materials
You don't want version V and probably not a synthetic either.
