Sorry to keep asking regarding parts. Can anyone tell me where these two rubberized clips go please..?.
Also, I found one of the rubberized clips (second pic) that go on the drivers side motor mount bolt for the positive battery cable.....I think there should be two..??. Will one work..??.
I also ordered the two clips (third pic) that go on the drivers side oil pan to hold the positive battery cable.....should I use those instead or both types of clips are needed..???.
Thinking more about this, mine are on the right rocker retaining the rear antenna lead and speaker wires. Do you have a rear antenna? I just spaced them equally in the door opening.
