Posts: 32 |
I have a 69 Firebird. On the Firewall ( which I have had mine smoothed out), down low on each side where the access holes are for the subframe bolts, does anyone know of any type of covers that are made for them? Thanks Jerry
Posts: 1,770 |
The drivers side has a mastic type layer with a clip that covers under the fuse box. The passenger side is nothing, but there is the inner fender well seals that go and block a lot of that area. The seal kit is reproduced all over the place but that clip for the drivers side firewall seal is not reproduced. If you search my posts a while back I had put up some pictures that could help you.
Posts298,849
1,097
123
