A/C evaporator for 67-69Firebirds. This is the original unit made by Harrison/Frigidaire and is in great shape - was tested and has no leaks. Cost of new imported unit is $400+, asking $200 plus shipping.
Not sure if I understand your question by "condenser side". You asking if I have the condenser? If so, the answer is no, I don't. I do have the original accumulator with hoses attached and new expansion valve and new rebuilt original style A6 compressor.
This is an original evaporator, so it will fit with original equipment, whether you have the original AC set up installed, or are planning to install an original set up.
