Hi fellow members I have a question hoping someone could answer. I have a 67 Firebird that came with a sbc in it and I'm going to put back a Pontiac 400 in it. My question is do I need to change the drive shaft? It's a 4 speed Muncie and I plan to use the same transmission. Thanks
They have plates welded to hold chevy mount over top of where the Pontiac mounts bolt into subframe. I will find out once I grind those out.Thanks! Cheers!
Has the subframe been changed?, can you post any pics of the plates your talking about? If someone put a 73-74 Nova subframe in it , they had a small plate welded on it from the factory
