Typically it’s wired on the neg side of coil if stock setup if aftermarket is mostly the same unless the distributor has a tach lead Make sure you have ignition power and ground at tach and make sure it’s hooked to ground side of coil Here’s a wiring diagram to help check the fuse in the wiring if its still their
