Posts: 52 |
Hi everyone I’m planning on putting a hood tach on my 69.... First I have to find a good 400 hood..... ( not sure if I want a aftermarket hood vs a original 400 hood ) Same for the hood tach...... What are the pro’s and con’s on original vs aftermarket hood tach......? Is it worth restoring an original.....? Maybe using an original housing with modern guts....?? Engine is a 70’s Pontiac 400 with HEI distributor ...... Also want the 69 Trans-Am gauges ( stack gauges ) ( but I don’t think anyone makes them anymore ) so not sure what in doing there yet..... Do know that I will have a tach,Speedo,and my four vitals.... in the dash without hacking up the dash bezel..... And then I’ll add the hood tach as well...... Thank you in advance This is just one of the many projects I have planned..... lol ðŸ˜
Here is my 69.....
Posts: 52 |
This is the hood tach I'm looking at...... Any ideas on where I can get it redone....?? Maybe I can clean and touch up the face myself...??
Posts: 309 |
I would consider it a waste of $$ buy a good one from "RC tach shop" https://www.rctach.com/
Posts: 6,758 |
x2 It's stuck so the main component is done so not worth rebuilding. The case looks poor as well. Buy a good aftermarket tach.
Posts: 147 |
x3
Ordered one from RC Tach a couple yrs back to replace the original on my 68 and works/looks perfect, and works with MSD without any special adapters!!
Posts: 36 |
Anyone know if there’s a hood tach available that will run off of an LS ECM?
2,192
74
