I'm sure this has been covered but I guess I'm not searching with the correct terms. What is the correct procedure to prep the grills and is there any paint/dye that matches the factory color. Thanks
I lightly sanded them , and yes it looks pretty close, close enough that it seems to match the parts I didnt paint (inside the chrome trim ring), if you need to paint that part too, maybe use a paint remover and spray them off?
