Has anyone had problems with door gaskets not fitting right and blocking window channels which almost stop you from rolling up the windows I have the oer brand and none of the holes line up When I mean the holes don’t match I’d have to stretch the gasket almost 2 inch I’m afraid it’s going to break I could drill new holes The ends are going to have to be cut down especially on the front of door it blocks the hole window channel The rear end of door just needs a little trim not much If it will help a can post some pictures this evening
OER is about the worst weatherstip maker for fgfs out there. Metro mold is about as good as you can get. I tossed a few sets of OER many years ago. Way too stiff, and fit was horrible!
