Windows are easy. Use a little laquer thinner and be careful to not let it drip on anything. Interior parts are a little touchy. You could use Armour All and rub. Jim
If its recent paint job its easier...you can try some laquer thinner on interior , make sure to try a spot first where its not seen to verify it wont damage the upholstery... I`ve done it successfully several times, but be careful, little at a time, patience...
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> paint will come off glass very easily with a razor blade also </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes,it will, but since the glass will scrtch easily , be careful with your angle of razor blade vs w/s...use a very low angle, like 2-3 degrees...
