Hi All, Prob a simple answer, but... 10 bolt, 1968, 3.36:1, LSD rear end. Just to paint you a picture: I pulled it out and cleaned it up, 2K painted the housing and axle cylinders, and powder coated the brake back plates and cover. Now time to rebuild. Just checking: Seems to be about 2 quarts of 75W90 gear oil and 4 oz of LSD additive... I imagine the housing needs to be level (its in a cradle right now). Should I stir the additive into the oil before I fill the pumpkin? Does anyone do that? The cover will be on so what's the best way to fill it? Any other recipes you like better?
Am I making this more complicated than it needs to be?
'68 400HO Coupe, 4 spd, 259 interior, Windward Blue. My other car's a Johnson 15 outboard on a '61 Starcraft rowboat... Just sayin'.
You know you are! Fill though the fill hole with the rear end approximately level. Add the additive first. Then fill with oil until it starts to dribble from the fill hole. Put the plug in. Done.
I have my dad's old plunger filler tool with flexible steel pipe to inject into bottle or can of oil, suck it in and the put pipe into hole on the side of diff and push oil into diff. Make sure diff is level. If you have too much it will just flow out. Put the additive in first.
So I filled it a little differently. Since it was off and in a cradle, I rotated it up, filled it with almost two quartsof 75w90 gear oil and 4 oz of LSD additive. Then closed it up, rotated it evel, and pulled the plug to top it off. Now just need to touch up the scuffs from the cradle!
