I just dropped my tank, and I have 2 questions for you guys. (67 bird), I have a new tank that is going to be here next week.
Updated, the sock is ripped!!!
Also The hose that goes from the filler neck to the fuel tank is rotted away, can I just use heater hose of the same diameter to replace it? Or does it need to be some kind of special curve???
I just went through the same thing about a week ago and my filler neck hose was rotted also. I talked the guy at napa in cutting me off just what I needed from a spool for a couple of bucks.
yea I think I will have to stop at the auto store this weekend and pick up some fuel hose.
Is the fuel sock something I have to order repro from the ripoff catalog companies? Or could I find it locally?
If I have to order from the catalogs they have the regular one(im guessin 4in long doesn't say), and the one that is 4-7/8" inches long.
My stock one is 4" long, but the the 4-7/8" inch one is longer and $2 cheaper, Could I go with that one? I don't think a little bit longer would hurt right?
