#326536 05/09/20 06:18 PM
I am upgrading from 14" to 15".
I found some rims with an HM code on it.
I tried a test fit and they seem to rub on my 4p calipers. I will probably try spacers.
I think it is a 15x7 rim. Not sure which trim rings to get. Haven't tried my center caps yet.
Any advice would be great.
67 Firebird 400. 30k orig miles, 4 speed, ps, pb, pw,
front disc brakes with dual piston calipers, ac, hood tach, triple black.
Danmc9 #326542 05/10/20 09:14 AM
Interesting. Are these GM 4 pistons or aftermarket. I have 14X6 JC Rallys on my car with single piston calipers (69 style), I had to grind a little off the brackets, but they clear. Is the clearance issue is on the front of the wheel hence spacers.
Larry
1967 Sprint Convertible
hokie1984 #326548 05/10/20 03:28 PM
They are the original factory calipers. The back of the rim is touching the caliper.
Danmc9 #326557 05/11/20 08:11 AM
That's what I thought. Too many variations Rally wheels. With the factory calipers you should be able to install factory Rallys on that car. Are you dead set on 15" wheels.
Larry
hokie1984 #326739 05/23/20 12:12 PM
I need to buy new tires. I have the 15" rims. Just have to paint and get trims. I figure it will be better than the 14"s.
Danmc9 #326761 05/26/20 09:08 AM
U
U Offline
Those are in fact 15x7 and were used on all sorts of Pontiacs, including Firebirds from 73-81. If that is worth anything to you...
U
U Offline
Either that or the HMs were only used on 73 Firebirds. Hard to tell what the site means. Either way... 15x7 Pontiac Rally2. 70s.
