Mounted up the multi-leafs I had sitting around on the rear for the 67 today. I wonder how jacked up it'll be in the rear after I get it in. May have to run around with some sandbags in the trunk for awhile.
Cool. You doing the traction bars? I worried about the shock length using the 67 lower plates with the multi leafs because the mount will be lower. It worked fine. Plenty of shock travel
Yeah I still have to order up the bushings. Then I have to see if I can find somebody that makes the snubber pad. I'm sure somebody has them. I was planning on using my old 69 shocks but didn't think about the fact that they mount differently on the uppers. I may just have to buy a new set for the backs.
Rear is in. Yay! Hardest part was turning it over so I could slide it under the car. I dont know it’s pretty bouncy. I suppose it’ll settle down after I get the rest of the weight on.
The traction bars look good. I'm still collecting parts to build my 67 rear. I've got the traction bars ready to go and a nice powder coated housing. I've got a couple of sets of 3.55 gears. I need a posi carrier and some axles and bearings and seals and ready for the rear end man to assemble.
