Posts: 95 |
I replaced most of my interior lights with led. Whatever I was able to reach under the dash too. Now a year later, driving with parking lights or headlights on. Intermittently when I brake or use my turn signal, they blink.
67 Firebird 400. 30k orig miles, 4 speed, ps, pb, pw, front disc brakes with dual piston calipers, ac, hood tach, triple black.
Posts: 1,015 |
It’s very possible the plastic blue colored strip where the wiring plugs into behind the dash/ speedo panel is worn out.. it could be grounding every once in a while causing this problem..
mark
Posts: 3,049 Likes: 10
Posts: 3,049 Likes: 10 |
LED's are a no load component and when the voltage drops in the circuit, they will do funky things like blink. Could be a bad ground as well.
These things happen when trying to integrate modern technology into 50 year old wiring harnesses and circuits.
Posts298,849
1,097
123
