Posts: 132 |
Why would the original window guide plates now rub on my new glass? The glass mounting hardware is hitting the plates and not allowing the window to roll all the way up.
Posts: 1,015 |
Only thing I can think of is (1) the length of the part is too long.. or (2) the window is still out of adjustment..
mark
Posts: 853 Likes: 3
Posts: 853 Likes: 3 |
what part of the hardware is hitting the plate? the backside rounded part of the atachment screws are supose to rub on that plat to hold it in place when the window is up all the way. This guy has a lot of good info videos https://www.youtube.com/user/MrScaredshiftless/videoshere is one part of his door glass install and adjustment videos, he is showing it on a Camaro, but it is the same for our Firebirds. I just got done installing all new door and quarter glass on my 69, these videos helped me alot https://www.youtube.com/watch?v=UiDuzuqjmnA&t=2s
Wade
Posts: 853 Likes: 3
Also, did you remove those plates? If so , are you sure you got the bottom lip of the plate over the metal piece on the door frame?
Wade
Posts: 132 |
Yes, I did remove them about 10 years ago and I did not have them in correctly - Thanks!
Now, I still cannot get either side window to go down all the way - they stick up a good 1.5 in. Stops are loose. Any suggestions?
2,110
46
