#328219 11/17/20 09:36 PM
C
C Offline
I have a 67 convertible, it had a super turbine 300 in it. on the side was a purple wire that plugged into the transmission. everything I have found says it's a kick down wire, so where does it go top side?
D Online: Content
It should go to a connector that attaches to a kickdown switch mounted at the carburetor. The connector at the carburetor is 2 wire. The switch gets power from the wiper motor connector on 68's, not sure if it's the same on the 67's though.
C
C Offline
Thanks, I'll just half to trace it up as the kick down switch is long gone.
N
N Offline
The parts you need for the carb connection are easily found online. If properly installed you should see a dramatic improvement in performance. The attached shows a TB400 switch assembly. Not sure it will work with your tranny, but what you need is out there for sure.
