Not sure if anyone else has seen this, but I just came across this tool kit to install control arm bushings without a press. I know a lot of you can make your own tools, but this has all the right size collars so you don't have to try and find them.
Very nice tool. I have done these w/o a press by hand with a torch, pipes/impact sockets and Hammer when I had to but defiantly a much harder fight then with this tool even though they are pressing out recently installed bushings not 50 year old rusted ones. The only thing I would suggest is that this would not come in handy as a multi use tool nearly as much as a hydraulic press would during a restoration once you get familiar with it. With the price of cheap Pittsburg harbor freight presses compared to this $100.00 mostly one time use tool you would be better off to invest in a press if you have the room.
I know what you are saying, I too use my press to install them but I use my air chisel to remove them. I was just sharing this for those that don't have the space for a press
