I have 2 harnesses that I have not figured out yet. I may have figured out one? can anyone direct me in the correct direction. 1968 Firebird 400 convert.
I can't quite recall the first one maybe washer pump harness? The stock photo between your photos - the orange wire with the rubber grommet I believe is the splitter adapter wire for the trunk light option. Hopefully someone can chime in because my memory is foggy.
I know the orange harness has something to do with the convertible top to breaker wiring I think? The other one is not a washer harness. That is apart of one of the main harnesses. That is already hooked up. But thank you for chiming in!
I think you are correct. Looks like that is the dash side of the harness. Anyone know where it goes through the body or the dash to hook to the lower harness?
