#329880 04/26/21 10:22 PM
L
L Offline
I have a stock 1968 Firebird convertible. The car currently has the factory non-power Drum brakes. I’m planning to put a set of power disc brakes on the car. The factory wheels are 14 inch and I’m thinking about going with a 15 inch rally wheel. Do I need backspacing or no to work with the disc brake kit? Not big brakes just standard disc brakes. Any comments would be appreciated, thanks
Leonardp59 #329904 04/27/21 07:42 PM
Any 15's should be fine, I believe. Some 14's will even work, with or without a little grinding on the brackets.
