The 1967 Hardtop I have has a TH350 installed with an SBC 350 as well, the car was originally an inline 6 with a manual box. BUT the shift lever was never installed into the car, I just have the gear selector cable coming up thru the factory hole in the floor.
If I keep the TH350, what are my options for a gear selector knob etc for the car, or if I go back with a manual transmission what would be a good choice (keeping either the SBC or finding a 400)?
Here is a video on how the transmission is currently in my '67 Bird.
Again thanks for all the suggestions in advance gentleman.
I'd turn it back into a manual trans car now and run the engine that's in it, you can always add a pontiac engine later. Also, sounds like the starter may need a shim or two? What are your plans on that roof?
It is crying for a poncho 400 with a muncie 4 speed!
Agreed.
I've always had muncies in my pontiacs and my buddy ran a super T10 in his 65 goat, he always thought his ST 10 was stronger, maybe it was, but they all held up fine. I used to own a 1970 camaro with a built SBC and it had a saginaw 4 speed behind it, somewhat light duty compared to the previous ones, but I had no problems with it either. Currently my 66 GTO has a factory HD Dearborn 3 speed top loader in it, actually built by FORD for Pontiac, it's probably the strongest of the lot. If I were building your bird, and depending on what gears are in the rear, I'd go with a muncie M20 or M21, they're not hard to find used. If $$$ is an issue, the top loader 3 speed are cheap to buy and are a really stout piece. That roof may have some hidden surprises, if so pick up a clean one and put the whole thing on. I just did a search on Ebay, and found a firebird/camaro Dearborn 3 speed with the correct factory shifter. If it's a good unit, that'll be a pretty cheap way to get a manual in your car.
