#330379 06/16/21 04:12 PM
K
K Offline
Hey guys, anyone know where I can find ID numbers to tell what tranny I have?
I am finding that this car was parted together and not sure what I have or if tail is correct for a 1968 bird. Was told it was a turbo 400 but I have had alot of surprises so far. Thanks.
kelly #330381 06/16/21 04:30 PM
T Offline
Look at transmission pan shape. Does it have a cable on right side for kickdown? ( T-350) Is kickdown switch at carb? Find a transmission fluid pan chart to identify your transmission. Google it!
The 400 pan will look similar to the shape of Texas and the 350 is basically square shaped with a missing corner
1F59406A-4838-4E4B-AE6E-864194AFAC97.png CD54111C-646E-40E0-BF82-AF24B3F6E966.png
K
K Offline
Got it. Thanks.
kelly #330418 06/23/21 08:22 AM
K
K Offline
OK. Still trying to find if this tranny will fit the '68.
On bottom of pan it reads: Hydromatic division of GMC.
On side plate: 73-PC and 2884 with a big " D " on the tail shaft. Any ideas?
Also I was wondering what the length should be. Thanks.
kelly #330420 06/24/21 01:50 AM
Well, it seems like the transmission comes from a 1973 Pontiac full-size car with a 455.
* 73 = 1973
* PC = 455 V8 4bbl carb, Pontiac. Look here: http://www.teufert.net/trans/t-400.htm
* 2884 = I think this is the transmission serial number.
Sorry, I don't have any answer to you other questions, but I hope someone else will chime in.
1969 Pontiac Firebird 400
1966 Chevrolet Corvair Monza
K
K Offline
Thanks for the info.
