Anyone know where I can get disassembly instructions for a 67 tilt column, floor shift?
I am wanting to do a general rebuild. Got most of it apart but can't see how to get the upper housing off that holds the short tilt shaft or how to get that tilt shaft separated from the long shaft to get at the bearings.
Do you have a factory service manual? As I always say when all else fails look at the instructions (or manual in this case) If I remember correctly 7&8 tilt columns are the same so Here is the 68 Manual courtesy of Harold B. https://www.firebird400ho.com/mdocuments-library/ Go to section 9-14 preview in the service Manual. Good luck.
Thanks barnbird. I don't have that manual but just downloaded that section. It shows how to get it apart. There's a lot of info for the regular column. Looks like this won't be easy as there are some special tools required.
