T Offline
Hey, I could use some help. I took my alternator off to replace my lifters and to do so, I had to remove several of the PS pump bolts / spacers... Now I find myself wondering WTH goes where... I think I have it figured out but would like some help to make sure. I think the one bolt / spacer I haven't figured out is shown in the attached, but I'm not 100% and hope y'all can help a fella out.
I looked at my '68 but cannot see any spacers. Maybe they are hidden. If you want I can use a snake camera to see if I can find them from underneath. However, maybe Illustration 11 here will help: http://www.teufert.net/partbook/67-76/6-i.pdf
Edit: I looked again tonight with the snake. I saw, what I believe, is the spacer you are questioning. It is between the larger bracket (#20 in the dwg.) and the pump just like the drawing shows. I don't think that bigger bracket has ever been off my car.
'68 400HO Conv.
