I just recently bought a 69 bird and need some help with the engine decode. I contacted Pontiac Historical Society and they sent me all the info about my bird but the engine is different. It originally came with a 400 but someone swapped out for a 350 unfortunately. Below are the codes but what’s odd is, while looking for these numbers I found Chevy orange paint around the block and now it’s a dark blue color, not the light Pontiac color, I believe they used that dark blue after 69 but not sure. Any help would be greatly appreciated, I’ve been researching but haven’t found much yet..
Number by timing cover, pass side: 290124378 (I believe it’s a 0, hard to make out) Back pass side of block, near head: 9790079 Front pass head: 0411630 WM Number stamped between frost plugs: 350
