Just brought home a 67 400 4spd. The car needs everything, but has the original rear end and mono springs that will not be used for the build. Have to do a bit more wire brushing on it to confirm the gears but it looks like it is a “Z” code rear end. It was a factory std trans car so it should have a desirable gear ratio. Like to see it find a good home. Will confirm ratio and price. PM or call if interested. 530-696-0835 Ron
