Complete exterior and interior led lighting packages or individual lights. All products are designed to keep the stock look when turned off and then much better visibility at night. Installation doesn't require rewiring or other modifications. Install instructions included.
I have a 1967 Firebird I used to make sure everything works correctly, and I can help with install or other questions. Other than some small modifications to the headlight buckets everything else is a bulb swap and a fairly easy install. Tail lights don't require taking the lights apart or anything like that.
We now also have Digi-tails tail light panels available for 1967-68 Firebirds. Digi-tails use a circuit board instead of bulbs for the taillights so they are sequential. Taillights have a fluid, sweeping pattern when brake or turn lights come on. Looks better and makes your taillights more visible since the moving light catches people's attention more. Since they are completely led, they are also much brighter than stock.
New parking lights for 1967 Firebirds, these use a 3" led strip instead of a bulb. They use stock reproduction lens so look stock when turned off. 1967 Firebird LED Parking Lights
