Hello all, After connecting everything under the dash, I find my tail lights do not work! I have hooked up direct power to them and they work fine. Any ideas from anyone would be appreciated. One thought of mine is, Does the circuit go thru the steering column and could the harness be bad there? Help needed please. Everything else works like they should.
So you are saying the column harness does have something to do with them.? I have tried a couple different harness too and still nothing. the green wire in the switch has power out but I loose it somewhere to the back. Still banging my head!! lol
