S Offline
Hi All, I am considering selling my 67' Firebird 400 /4-speed.
Car is an original CA car with good bones. No noticeable rust or corrosion on body, nor undercarriage, or in trunk or floor pans. I recently completed a stock rebuild of the 400 (transplanted from a 67" GTO) and Muncie M20. Did everything right with Butler Performance and BOP replacement parts and hand refinishing of whatever parts were salvageable. Sent Rochester carb out for rebuild.
Car needs a proper repaint at some point and some finishing touches on interior door panels and a new set of wheels and tires but not much else. Otherwise no remaining surprises. I've worked through most of the frustrating stuff. If you are good with paint jobs or have a reasonably priced painter that can do a proper body blast and paint you'd have a more or less finished car.
Note: PHS indicates that car was originally a 326 /4-speed. The 400 however is a 67" Pontiac 400 out of either Firebird or GTO with low miles.
I live in the Bay Area in CA. You can contact me at seanscott55@hotmail.com if you want to learn more. I have pics, PHS, receipts, etc.
Sean
