First post from a long time lurker- hello. I have a 1968 convertible that I am restoring. I don't have the original wiring harness. I need to know where the power top switch is located in the dash[?] or wherever it belongs. I used to have a 1968 hardtop so I am familiar with pretty much everything else. Thanks in advance.
YIKES!!!! Thanks for the reply. Are the two side screws for an aluminum switch? [having trouble posting a pic] Or does the switch reside in an aluminum mount?
I see, now I understand. Thanks. As I said don't have the convertible wiring, but I have several hardtop harnesses. I am looking at a 50 amp rated SPDT Momentary ON- OFF- Momentary ON toggle switch. While lurking I read all the posts about the switch failures so I decided I might rig up a switch to use while working on the car. I will be raising and lowering the top a LOT doing work. If it lasts maybe I will just install it in the dash and be done. I have 30 amp breakers, both old style and more modern marine versions. I figured it was either find a tough switch or use relays to take the abuse off the switch. I already made up a 10 gauge marine grade wire stand alone harness to go from the dash to the power top motor. The motor runs much better than it did. I am waiting on some of the hardware that was missing from the hydraulic cylinders to see if they will work the top as they should. Thanks again for the pic as a lot of my parts are missing.
