I removed the cowl and the wiper motor and found some small holes rusted through just below the wiper motor. It seems that water could just sit there and rust any repair I do currently. What is the best way to prevent this from rusting again? Is there a drain that I am missing?
Its best to pull off the cowl panel and clean out all the leaves and debris that's trapped down the sides where it supposed to drain. There's no real way to stop rust once it starts eating metal. You really have to cgind or cut it away then prime and paint the area.
