After a long search, I was fortunate to find a perfect set of folding rear seats. Even the color (Parchment) was correct. Don't ask what I had to pay to get them, it's embarrassing! I purchased all the aftermarket parts to make it work like factory. My problem is that the contour of the hinge brackets doesn't match the contour of the floor. These are supposed to be welded to the floor. I may be able to bend them to match, but they are thick steel. I hope someone here has had the same problem and can respond. The floor is original to the car, which is a 67 Coupe. Thanks John
not sure this is what you're after but here are a couple pics of mine. My 67 coupe had the folding rear seat from factory so I didn't add any brackets. I did remove then to clean up and then re-weld. sorry I don't have the pics of the welding on this computer
Not trying to hijack the thread, but I have a similar problem. I saved a folding rear seat from a 1967 coupe. All the brackets are there. Would that fit in a 1968 convertible?
