Thanks in advance. Need help getting that L/H Astro vent out. What a PITA. The cluster trim is being held in place solid on the L/H side after removal of all screws on the R/H side and across the top. I don’t want pull at all as I know it will break. I can’t get my hand up there to release the headlight switch, I’ve removed the e-brake assembly and still can’t get it out. Do I need to remove the full padded upper dash 1st? Can you remove just the 1 trim piece that surrounds the cluster and radio in 1 piece? What am I missing? Can’t find any YouTube videos either.
