#335335 01/22/26 10:56 AM
S Offline
Hey guys- I have a '67 and the gas gauge shows way past full- it doesn't react or change when the ignition is on. I had seen someone's post saying it was most likely a ground issue, and they had posted an image to help, but I can't find that link anywhere, and don't know where to start looking for the ground issue. Little help? Thanks in advance
'68 400HO Conv.
S Offline
Jim, thanks- that will certainly help, but the one I was thinking about said something like if it showed on E then the issue was at the sending unit, but if it showed way past Full then it was a problem on the gauge side with a poor ground there.
Could be a bad ground anywhere in the circuit. Usually at the cluster.
1 member likes this: Surfin'Bird
I think the problem causing it to read full is the ground from the sender to the frame.
I agree. I would try to install a temporary ground wire from the sender, just to see if that would make the gauge work as intended.
1969 Pontiac Firebird 400
1966 Chevrolet Corvair Monza
