Hey guys- I have a '67 and the gas gauge shows way past full- it doesn't react or change when the ignition is on. I had seen someone's post saying it was most likely a ground issue, and they had posted an image to help, but I can't find that link anywhere, and don't know where to start looking for the ground issue. Little help? Thanks in advance
Jim, thanks- that will certainly help, but the one I was thinking about said something like if it showed on E then the issue was at the sending unit, but if it showed way past Full then it was a problem on the gauge side with a poor ground there.
