What is the best vacuum gauge to buy? Need to test the vacuum on my carb? Also once you get the gauge how hard is it to adjust the carb? Thanks in advance for your help.
It's a pretty simple instrument. I just went to my local parts house and bought the best one they had.
Also - for your 2nd question. If I remember right, the carb is adjusted to achieve a certain amount of port vacuum at idle. You just attach the gauge to a extra base plate port that is normally capped and rotate the idle mixture screws until you hit the manufactures desired inches of vacuum.
Send a PM to Carbking. I know he'll be able to help you out.
just adjust the idle screws for most vacuum at idle, dont forget to also adjust the idle speed when you do this because it will change, and recheck your timing when doing this
I have a harsh 2 1 downshift when cold and think it is vacuum related and not the tranny. Do you think using a vacuum gauge and adjusting the carb with it will help?
