i am confused on my code. it is supposed to be a 326. the engine code is: 9793079G. the nearest thing i found was a 68 and a 69 350. the 3 might be a 0 and the g may be a ???. any help appreciated. oh ya, the heads are 17's. what kind of hp. should i expect? what heads would work better??
From the info you posted, it might be a 1968 350 2bbl. rated at 265HP with small valve heads. If it's from a Firebird, code should be WC and should be mated to a 3 speed manual, or a YJ with a 2 speed auto. Same engine was also used in A body as WD or YN.
Heads should be okay, cam, intake and carb could be upgraded for more power.
the manifold is pontiac and it has a 600 holley and cam is???. if it is a 350, should i be looking for some 16's? i will be putting on a 200 4r tranny. the car is at the shop now being put together so i havent been able to get block #'s yet
