I am switching out my standard ratio gear box for a quick ratio, is there anything else that needs to be converted or will they interchange OK? Would I be better off just rebuilding the standard ratio? Thanks.
Some in our group have used the 2.5-3 turn version from a 78-79 Firebird. Not sure about the shaft until I do mine, but they used a universal rag joint kit which had enough parts to match up. Part number at O'Reilly is 27-6510, and it's about 150 with the core charge.
